StefanoC
3 years agofloat128 floating point IP operations
Hi all,
I noticed that among the parameters of the IP library one can achieve float arithmetic with float32 and float64, but that's it, 64 seems the maximum number of bits possible. Is there anothe...
ShengN_altera
3 years agoHi,
There is no problem at synthesizing the code above. You can either write your own custom code or use Intel IP. That is totally depending on you. Quartus don't have problem at synthesizing those operators.
Sheng
- StefanoC3 years ago
Ok great,
but still on the above code, during synthesis will Quartus internally use the Altera/Intel IP (automatically)?
Related to this topic, in a vhdl architecture assuming I have float64 signals, I will be forced to instantiate IP libraries to perform floating point operations among signals, right?
