Fitter Error with Clock Switchover Enabled in Altera PLL (Normal Mode)
Hi Ash,
Thank you for taking the time to reproduce the issue.
There is an important point I should have mentioned earlier.
The behavior you pointed out - "there is a flexibility to move to some other pins" - was something I had already confirmed on my side.
My apologies for not sharing this in my first post.
1. Behavior confirmed beforehand
With the following pin assignment, I had confirmed that the PLL was fitted into FRACTIONALPLL_X0_Y9 within the PLL strip:
- PLL Switchover Primary Clock: PIN_AF21 (clk2p @ BANK 3A)
- PLL Switchover Secondary Clock: PIN_AF20 (clk3p @ BANK 3A)
2. Why I cannot change the current pin assignment
On the target board, the wiring is already fixed as follows, so changing the pin assignment is not an option:
- PLL Switchover Primary Clock: PIN_N2 (clk15p @ BANK 5A)
- PLL Switchover Secondary Clock: PIN_M1 (clk14p @ BANK 5A)
3. Workaround using External Feedback Mode
When I changed the PLL Operation Mode from Normal Mode to External Feedback Mode, Fitting succeeded while keeping the current pin assignment.
Although this requires two additional User I/O pins (fbclk / fboutclk), they can be mapped to unused pins to useable on the board, which I plan to connect using jumper wires as a temporary solution.
In this case, the PLL was fitted into FRACTIONALPLL_X97_Y40.
4. Additional finding
Further isolation showed that the same error occurs even in a simple design using Normal Mode (with Clock Switchover disabled).
With the Reference Clock assigned only to PIN_N2 (BANK 5A), routing resources seem sufficient; however, as the error message suggests,
the Fitter appears to be trying to route the PLL feedback path across two different PLL locations( FRACTIONALPLL_X97_Y40 and FRACTIONALPLL_X97_Y31) .
Error (12349): Fitter was unable to route the far global PLL feedback path for the fractional PLL (2 locations affected)
Info (175029): FRACTIONALPLL_X97_Y31_N0
Info (175029): FRACTIONALPLL_X97_Y40_N0
Questions
Q2.
Apart from changing to External Feedback Mode or modifying the pin assignment (your suggestion), are there any other effective solutions for this issue?
Q3.
In a simple Normal Mode PLL design (Clock Switchover disabled), why does the Fitter attempt to route the PLL feedback path across two PLL locations( FRACTIONALPLL_X97_Y40 and FRACTIONALPLL_X97_Y31) ?
Understanding the root cause will help me gain a clearer view of this error.
I would greatly appreciate your advice.
- Ash_R_Altera3 months ago
I am opening an internal ticket to get help from engineering team on the root cause. It will take time to get a reply for them. I will update you as soon as I get a relevant response.
