anonimcs
Contributor
1 year agoFitter error regarding the EMIF IP
Hi all, I have a design on Quartus Prime Standard version 17.1. (I'm already considering an upgrade to 21.3 Pro after fixing this error, so please don't recommend this straightaway). In the design t...
sstrell
1 year agoShow your PD system with connections between the HPS and the EMIF IP. Have you successfully manually generated the system in PD?
anonimcs
Contributor
1 year agoHi,
Yes, the generation of HDL was done successfully. I attached some screenshots taken from the Platform Designer to this reply.
Thanks for helping out!
