Fitter can not place PERST pin for Multichannel DMA PCIE
- 3 years ago
Hi Arley,
We do not receive any response from you to the previous answer that I provided.
Also, I strongly believe that my previous answer had solve your problem (Please correct me if I am wrong)
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
Hi Arley,
Can you try to
set_instance_assignment -name VIRTUAL_PIN ON -to *pipe_sim_only*
set_instance_assignment -name IO_STANDARD "3.0-V LVTTL" -to pcie_rstn_pin_perst
ensure pcie_rstn_pin_perst is whatever this port is called in your top level.
the information contained within the S10 PCIe Example Design User Guide,
can you ensure that you have the following two assignments in your test project:
Wincent_Intel
Hi Wincent,
I just confirmed that both constraints are present in my QSF.
Additionally, the pcie_rstn_pin_perst pin is connected to the top level interface.
I have attached the QAR file here.
Arley
