Fuad1
3 years agoFIR II ip simulation warning
I’m using Intel Quartus prime lite edition and I’m getting the following frequent/multiple warnings when simulating the FIR II IP using Questa Intel starter FPGA edition:
Warning: NUMERIC_STD.TO_SI...
Kshitij_Intel
3 years agoHi,
Can you please check once more in the path mentioned below.
<ip_variation_name>folder/altera_fir_compiler_ii_1911/sim/
Please let me know if you are still not able to find it.
Thank you
Kshitij Goel
Fuad1
3 years agoHi,
I searched the entire computer. The folder (altera_fir_compiler_ii_1911) and the file (hb1s_altera_fir_compiler_ii_1911_kmsq6ua_rtl_core.vhd) don't exist. There is a folder called (altera_fir_compiler_ii) in the path:
C:\intelFPGA_lite\22.1std\ip\altera\dsp
But it doesn't contain the file. Kindly, advise.
Fuad
