11 years agoFIR and CIC MegaCores Altogether
I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in FIR. Simulation shows that signal is not interpolated... almost the same. In the generated test bench of the CIC IP, I noticed that input is allowed only when "in_ready" signal is high... when it's low the input is kept hold. I tried to do the same thing using Back Pressure feature in FIR IP, but because ModelSim doesn't allow mixed-HDL simulations (what a shame!) I couldn't verify. So, I used SignalTap instead... plotting the result on MATLAB shows a completely distorted signal! So... How do I use CIC along with FIR MegaCore? Can you please provide an example?15 Replies
1) If you are going to mix at 10Mhz then you need to upsample(interpolate) to 10MHz.
2) 10000KHz/178.571KHz is a weird fraction and = 10000000/178571 that I doubt if it simplifies any further. Then you have to interpolate by num/8 (8 done in rrc) and decimate by denum. I don't know if your cic will support that sort of figure. 3) use system clock of 10MHz on both fir and cic with a fifo in between to control rate. You cannot run cic output at 10MHz unless you upsample to 10MHz through FIR+CIC Who decides 178.571KHz. Is't an audio application? - Altera_Forum
--- Quote Start --- 1) If you are going to mix at 10Mhz then you need to upsample(interpolate) to 10MHz. --- Quote End --- I am going to mix at 100 MHz, 10 MHz is just an intermediate frequency, I think I am going to use a compensation filter with interpolation factor of 10. --- Quote Start --- 2) 10000KHz/178.571KHz is a weird fraction and = 10000000/178571 that I doubt if it simplifies any further. Then you have to interpolate by num/8 (8 done in rrc) and decimate by denum. I don't know if your cic will support that sort of figure. --- Quote End --- What I actually did is that I divided the 50 MHz by 280, I didn't write all of the resultant fraction but it exists in hardware. So I don't think I'll need fractional interpolation, or will I? --- Quote Start --- 3) use system clock of 10MHz on both fir and cic with a fifo in between to control rate. You cannot run cic output at 10MHz unless you upsample to 10MHz through FIR+CIC --- Quote End --- How do I upsample through FIR+CIC? I didn't get this. --- Quote Start --- Who decides 178.571KHz. Is't an audio application? --- Quote End --- I did :D I chose to send audio over air for demonstration purposes. - Altera_Forum
I am a bit lost between figures. (10MHz,50MHz,280,100MHz).
if your symbol rate is 50000/280 then you don't need fractinalupsampler you need to go up from 50000/280 to 100000 = 560 8 in rrc, 10 in comp filter, 7 in cic well just use a fir interpolator at 70 or two firs at 10 and 7 or rrc to go up by 56, fir by 10 - Altera_Forum
Yes that's what I'm going to do.
But do you know why ModelSim simulation failed to give correct CIC output? It's the same design... nothing changed. - Altera_Forum
I figured it out... reset signal of the CIC was going high before any clock edge rises.
Do not you just love this view :D https://www.alteraforum.com/forum/attachment.php?attachmentid=10294
