Fiiter can not place PERST pin for Multichannel DMA PCIE
Hi Wincent,
1) Regarding to LVDS SERDES,
I have successfully synthesized the same project for 1SG065HH3F35E3VG device and back-annoted the voltage pattern, as you can see below.
set_instance_assignment -name IO_STANDARD "HIGH SPEED DIFFERENTIAL I/O" -to xcvr_tx_out*
set_instance_assignment -name IO_STANDARD "CURRENT MODE LOGIC (CML)" -to xcvr_rx_in*
Then I constrained the project for 1SG040HH3F35E3VG using the same IO Standard and I have gotten the same issue.
2) Regarding to IOPLL,
after yout last message I have tried to constraint only the pins xcvr_rx/tx, perst and refclk. I assume that the correct pin to conect refclk is PIN_AC28 according to the 1SG040_HF35 pin list provided by Intel (attached the QSF)
3) Regarding to PCIe Gen3x16 from lane 1-4, I am trying to use PCIe Gen3x8 with 1SG040HH3F35E3VG. I am not sure which configuration you have suggested to check.
Since it is successfully compiling for 1SG065 with no pinning constraint, shouldn't it compile for 1SG040 as well?
Arley
