greenlantern01
2 years agoFIFO Reset
Hello, I am currently using DE10 Standard FPGA along with DC2390 daughter card. Using DE10 Standard to capture the ADC data from the daughter card. After capturing this data the data is forwarded to...
greenlantern01
2 years agoHi,
Yes, I tried toggling it back as well. No use. After it is reset the FIFO doesn't accept any values and can only get 0 as the FIFO output.
Ronald
greenlantern01
2 years agoI tried sending reset signals to both the pins. When I try to reset the "reset_out" pin, my code hangs.
When I try to reset the reset_in, the FIFO resets but also doesn't accept any new values.
What to do?
