omerc
4 years agoFFT Intel FPGA IP (altera_fft_ii) unexpected source error (missing sop)
Dear Intel FPGA community members,
I am getting a strange error from the Intel FFT FPGA IP. The waveform from Signal Tap Logic analyzer is below:
I am raising the sink_valid and sink_so...
Kshitij_Intel
4 years agoHi Omer,
Is there any message or warning you are getting while programming the sof?
Some suggestions
1) Make sure the sof should be generated with the correct device, I mean should match with the signal tap.
2) Try programming the sof through the programmer instead of signal tap, if you are doing so.
3) Power OFF-ON board once, then try.
Please let me know, if you still face any issues.
Thank you
Kshitij Goel
