akaanb
3 years agoFailing to run on hardware Nios II
Hi, I am trying to create a memory test program for an old mass produced product. The FPGA is Cyclone IV EP4CGX50. I am trying to use ALTMEMPHY IP because this is what was used in the product and ...
Jacob11
3 years agoCheck the reset vectors in the NIOS 2 IP. If the reset vector points to uninitialized memory then you get these kinds of errors. I also have much less errors using the command line instead of the Eclipse tools GUI.
