16 years agoFailed to simulate DMA_Chaining example
Hi, Please help, i can't simulate my dma_chaining example in ModelSIM, I run "do runtb.do" file and got the follwing message: --- Quote Start --- ** Error: (vsim-3033) ../../../...
14 years ago --- Quote Start --- Hi Jeff, Did you ever figure out the solution to this? I am having a very similar problem. The simulation cant find the model for the Hard PCIe IP. It lists all the simulation libraries and then says it cant find it. Which library does it live in? Thanks, -Greg --- Quote End --- Hi, when creating the HardIP in megawizard, in the last step, do check the "Generate Simulation Model" ... this will generate a <name>_core.vo file. Compile this file during simulation.
