16 years agoFailed to simulate DMA_Chaining example
Hi, Please help, i can't simulate my dma_chaining example in ModelSIM, I run "do runtb.do" file and got the follwing message: --- Quote Start --- ** Error: (vsim-3033) ../../../...
16 years ago'altpcie_hip_pipen1b' instantiates the Hard IP block for the PCIe core. It's usually located in the "pci_express_compiler-library" under your Quartus II project directory.
What version of Quartus II are you using? And is this a design from one of the Application Notes or did you create the design yourself? It sounds like the modelsim script didn't have all the files needed to be compiled.
