Failed driver initialization of Serial Flash Controller II Intel FPGA IP
- 3 years ago
Hi Sheng,
I have received some information regarding this topic from another end. An acqaintance of mine contacted the Intel support directly and just heard back from them.
Here's the answer he received:
There is a mistake in the Platform Designer for the "Serial Flash Controller II"
The "Serial Flash Controller II" IP does not support external flash such as Micron.
If you refer to the document located here:
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-2/configuration-device-types-85589.html
Somehow there is a bug in the platform designer for the "Serial Flash Controller II" that the drop down list showed other flash option than intended.
The correct IP that the customer should use is the "Generic QUAD Flash Controller II".
If you see the code, there is a shift of 2 bytes to properly read the "memory capacity" byte instead of the device ID.I verified his suggestion to use the "Generic QUAD SPI Controller II" instead. Now it gets initialized automatically in alt_main() like a charm.
Thank you for your effort!
Best regards
Dominik
Check this https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-guidance/configuration-support.html under Intel® Supported Configuration Devices - Intel Supported Third Party Configuration Devices:
- Intel Quartus Programmer set the non-volatile configuration register during programming operation. User need to set the register manually if using a third-party programmer.
So probably have to manually make changes to altera_epcq_controller2_regs.h at line 261:
#define ALTERA_EPCQ_CONTROLLER2_DEVICE_ID_DATA_0_REG (0x20)
Sheng
- DomBraLV3 years ago
Hi Sheng,
I am using the Intel Quartus Programmer, so unfortunately, I don't see how this applies to my case.
But still, I'm curious: what changes to said line 261 would you suggest?
Dominik
