F-tile transceiver IP simulation
- 3 years ago
Hi Sir
I have checked the user guide, out_systempll_clk_ and out_refclk_fgt_ ports are not supported for simulation, and there is no current plan to support this.
There is a small note that mentioned this in the User Guide (page 110 and 222):
"Ports ending in "_link" must connect to the F-Tile Reference and System PLL Clocks Intel FPGA IP. These ports cannot be simulated."
PDF link to this user guide: https://cdrdv2.intel.com/v1/dl/getContent/683872
The understanding is that the System PLL outputs are not visible in simulation, but they are operating "under the hood". This would explain F-Tile PHY functionality even though the System PLL *appears* to not be functional in simulation.
For others that came across this problem, the solution that worked (which I discovered through the example designs provided) is:
- In quartus, run the 'Logic Generation' option in 'Project Overview'
- This will generate a directory called 'support logic'
- Run 'Generate Simulator script for IP'
- In your testbench, add this entity declaration:
- <top-level-entity-name>_auto_tiles_inst : entity <top-level-entity-name>_auto_tiles.<top-level-entity-name>_auto_tiles;
- There are no ports on this entity
- This entity is declared in 'support_logic/<top-level-entity-name>_auto_tiles.sv'
- 'mentor/Modelsim.ini' loads this entity into memory
- Add the top level with it's own name as the entity label:
- e.g., <top-level-entity-name>: entity work.<top-level-entity-name>
- Now you can run the simulation.
