F-Tile PCIe Root port - rx_st_hdr_o
- 2 months ago
Hi Serge93
The signals rx_st_hdr_o[127:0] are valid when rx_st_sop_o=1 and rx_st_valid_o=1, as these conditions indicate the start of a valid TLP packet on the RX Avalon-ST interface.
However, this does not imply that rx_st_data_o[127:0] is also valid. The F-Tile RX interface uses separate parallel buses for header and data. The validity of rx_st_data_o[127:0] is determined by the TLP type, specifically the Fmt field in the TLP header carried on rx_st_hdr_o:- When Fmt[2:0] = 000 or 001, the TLP has no data payload (e.g., Memory Read, Completion without Data), and rx_st_data_o must be ignored.
For a Memory Read (MRd) request, the TLP consists of a header only with no data payload.
Please let me know if this addresses your questions.
Ven
Hi Serge93
Thank you for reaching out.
Allow me some time to look into your issue. I shall come back to you with findings.
Ven
