ethernet_100g_loopback_off
You can probably try running some example design and compare the pin assignment between the working version and the one you are seeing this error.
- Vamsi_212 years ago
The compilation _test_design is the only working version for which i got same results for both loop_on and loop_off as i mentioned earlier.
For the hardware_test_design there is no working version , I had always got the error:"TTK failed reading from PHY slave, cannot enable TTK functionality for this PHY. Please verify the reconfig_clk is running and ensure this PHY is not stuck in reset."- Chris0392 years ago
I cannot find the hardware_test_design in the QAR that you have shared earlier. I tried to generate an example design using the ex_100g.ip. I notice that the pin assignment for the compilation_test_design in your QAR is different from the one generated.
Can you share your latest compilation_test_design and hardware_test_design for comparison? Are you using this devkit?
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/10-gx.html
I believe you have to use the hardware_test_design for the hardware test but somehow the pin setting or clock input has problem.
