Vamsi_21
2 years agoethernet_100g_loopback_off
Hi, I have generated a low latency 100g design example by following the guide below: https://www.intel.com/content/www/us/en/docs/programmable/683371/16-1/quick-start-guide.html I tested the s...
Chris039
2 years agomaster_write _32error could be caused by the problem in the code or the clock.
1. Is the example design without modification working?
2. If example design without modification is working, do modify anything on the design itself (RTL, pin assignment, etc) besides the TCL.
3. If no modification made besides the TCL, you have to review the TCL again and see which line causes the error
