eSPI reads are failing in quad mode with frequency 33MHz in Max 10 device.
we are using intel max 10 device (10M04SAU324I7G) with eSPI configuration of quad mode on 33mhz frequency. we are seeing the below errors Oct 3 00:20:21 PA-560 kernel: [ 48.103006] AMD_ESPI: Err...
Maybe can check if there is any difference in the data signal handling between the single mode and other mode being used referring to Single I/O, Dual I/O and Quad I/O Modes in the document:
