Errors when using the "MAX 10 Single-Port Triple Speed Ethernet and On- Board PHY Chip Design Example User Guide"
Hi dlim,
I have another issue with my design. Now I am able to see the Avalon-ST signals which I mapped to the top level file top.v on my scope. But these signals do not appear as I expected (square waves) but more like sine waves.
I think that the risetime of the clock signal is not met which causes a sine wave instead of a square wave.
So I tried to test the Reference design in 100Mbit mode instead of 1000Mbit mode. But I can't seem to get the design in 100Mbit mode.
My question is: do I need to change the clock speed in the top.v file, by replacing enet_tx_125 with enet_tx_25 as clock parameter for the TSE MAC
Or can I change the clock speed through the System Console with the tcl script?
in the attachment you can see in orange the clock (enet_tx_125) which is way smaller than I expected. The green line is rx_dval, yellow line is rx_data[0] and purple is rx_data[7].
As you can see the data is not a squarewave as in my simulation.
Kind regards,
Mansur
