Murali_kumar
4 years agoError(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constr
Hi all, I have implemented the "e tile hard ip" single channel 10g ethernet interface in statix10tx device. The pin assignments are taken care as follows, reconfig clock -------------------- ...
- 4 years agoIssue solved, problem in pin assignment name in inside logic
Deshi_Intel
4 years agoHI,
Looks like you maybe facing E-tile pin placement issue as E-tile hard IP has its own dedicated pin placement rule
Have you tried out the E-tile channel placement tool as shown in E-tile Hard IP user guide doc page 326, chapter 4.1 ?
The tool will help to validate to ensure you are using the correct and valid pin location.
dlim
Murali_kumar
4 years agoYes it was solved and thanks for your effort.
