saranya
5 years agoError while adding avalon signals in signal tap.
Beginner here.
Trying to learn pcie.
I have configured pcie(qsys) with 1 lane and gen2 speed.I have developed a test code,where 256 bytes of data were read and written from/to fpga through pcie. ...
CheepinC_altera
5 years agoHi,
thanks for your update. It seems weird as you are signaltap the Avalon signals but error trigger out related to the transceiver pin. Can you please help to create a simple test design with one PCIe instance + signaltap which could replicate the observation? I would like to further look into it. Thank you.
saranya
5 years agoHi,
As you mentioned, I had created a simple design with one PCIe instance only. I compiled the design without adding stp file,it got compiled.I didn't see any error.I face those errors only when I'm adding stp file and then compiling the design.
Is there any attribute in altera to mark the signals as debug signals in the design?
