10 years agoError in using megacore functions on Simulink
Hi, I have licenced versions of DSP Buider 13.1, Quartus 13.1 Subscription Edition and Matlab R2014a. While trying to double-click on "fir_compiler_v13.1" blockset, I am getting such an error: ...
10 years agoIn that case, it could be a path issue. See if it works if you install Quartus in the default C:\altera directory. There might be that simulink isn't aware of where your Quartus installation is located. Check that your PATH and other environment variables are correct (see the Quartus install guide for details).
