13 years agoError evaluating 'PreSaveFcn' callback of Input AlteraBlockset block
Hi, I have installed the latest Quartus II with the DSP Builder, combined with the 64-bit version of MATLAB R2013a (8.1.0.604). The operating system is Ubuntu 12.04. As much as I can see, all b...
13 years agoI have the same problem as you
when i run the >> alt_dspbuilder_createComponentLibrary Error in block : Arria_II_GX_EP2AGX125_alteradspbuilder2/4-Bit DIP Switch Java exception occurred: com.altera.dspbuilder.simulation.MaskInitialisationException: Exception in block 'Arria_II_GX_EP2AGX125_alteradspbuilder2/4-Bit DIP Switch'at com.altera.dspbuilder.simulation.Mask.init(Unknown Source) Caused by: java.lang.NullPointerExceptionat com.altera.dspbuilder.simulation.Model.getAbsoluteTestbenchPath(Unknown Source)at com.altera.dspbuilder.simulation.Model.getValidIOFile(Unknown Source)at com.altera.dspbuilder.simulation.Model.getSaltFileForBlock(Unknown Source)at com.altera.dspbuilder.simulation.blocks.IOBlock.getIOFile(Unknown Source)... 1 more An error occurred during a callback while saving 'C:\altera\12.1sp1\quartus\dsp_builder\bin\mdllibrary\Arria_II_GX_EP2AGX125_alteradspbuilder2.slx'. The previously saved version of this file (if any) has not been changed. Error in save_system (line 38) throw(e); Error in C:\altera\12.1sp1\quartus\dsp_builder\bin\matlab\alt_dspbuilder_createComponentLibrary.p>alt_dspbuilder_createComponentLibrary (line 28)
