qrive1's avatar
qrive1
7 years ago
error 14996 & 175001 of fitter placement in Quartus 18.1 pro
Hello everybody,
I get error on the fitter placement on Quartus 18.1 pro for a stratix 10 GX.
It can't place the i/o component (gpio ip) used to set the direction of i2c channel.
I need to use the i2c channel with the NIOS in order to enable an optic communication. My project is attached.
I already encounter these kind of fitter placement error and I never understand/identify it properly so a general explanation would be a good bonus.
  • Ahmed_H_Intel1's avatar
    Ahmed_H_Intel1
    Can you please try to remove all the pin assignments and let it auto-fit?
    f it still cannot fit, i think most probably it is due to the PLL cannot support many channels.
  • qrive1's avatar
    qrive1
    I "solved" that issue by using Quartus 18.0 instead of 18.1 . The generated ip must be slightly different between the two versions.
    The pll can't be a problem because if you remove one of the two ip gpio, this error is not throwed anymore.
    Ahmed_H_Intel1
    Thanks Quentin rivera,
    Thanks for your hard work, great to hear this good news from you .
