qrive1
7 years agoerror 14996 & 175001 of fitter placement in Quartus 18.1 pro
Hello everybody, I get error on the fitter placement on Quartus 18.1 pro for a stratix 10 GX. It can't place the i/o component (gpio ip) used to set the direction of i2c channel. I need to use the...
qrive1
7 years agoHi,
I "solved" that issue by using Quartus 18.0 instead of 18.1 . The generated ip must be slightly different between the two versions.
The pll can't be a problem because if you remove one of the two ip gpio, this error is not throwed anymore.
