gcohe5
6 years agoemif burst size configuration
hi I'm using a Arria 10 development kit with a DDR4 memory. I want to enable a burst size of 1024 (the maximum the avalon bridge ip allows). The EMIF connected to the HPS is configured to burst s...
BoonT_Intel
6 years agoHi, You can generate the example design and check how its work. Then compare with your traffic pattern and see any difference.
You also can run the simulation of the example design.
