ymiler
Contributor
3 years agoECO issue
I try to change the LUT output value by the command " modify_lutmask "
The TCL file includes the content : modify_lutmask -to eco_sig_1_cZ~0 -mask 0x1
But I get errors when I begin the pe...
Nurina
3 years agoHi Yishay,
As mentioned above, you need to connect the DATAF port.
Add connection to DATAF port https://www.intel.com/content/www/us/en/docs/programmable/683873/current/change-routing-connections.html
Nurina
ymiler
Contributor
3 years agoHi Nurina,
If I sum up what you're saying ,
1) when I want to mask spesific LUT - I must mask all others LUT even I dont want to do it .
2) I should be aware that "mask" ECO most of the time doesn't enough , I should do more ECO commands like "make connection"
Agree ?
Yishay
