ymiler
Contributor
3 years agoECO issue
I try to change the LUT output value by the command " modify_lutmask "
The TCL file includes the content : modify_lutmask -to eco_sig_1_cZ~0 -mask 0x1
But I get errors when I begin the pe...
Nurina
3 years agoHi Yishay,
When you modify the LUT Mask, Quartus will modify the LUT Equation to fit the LUT Mask. So when you change the mask to F3 & F2 = 0, Quartus requires to have the f logic in the F3 & F2 LUT Equation. That's why you receive an error regarding DATAF port.
Whereas when F3 & F3 = F you get no errors because Quartus doesn't depend on the f logic for this LUT Mask.
Nurina
- ymiler3 years ago
Contributor
Hi Nurina
I dont uderstand , what is the probelm to define the masks to F3 & F2 = 0 ? why does it cause to error regarding DATAF port ?
why its regarding to DATAF ? why I have spesific problem with DATAF ? why not with DATAB as well ? or all other ports ?
Yishay
