mel_tong
1 year agoE-Tile Transceiver PHY Agilex data rate is 10G, but hssi_ehip_lane_ehip_rate is rate_25gx1
Hello,I configured the E-Tile Transceiver PHY Agilex7 IP ; and the Transceiver configuration rules is Gearbox 64/66 ;mode is TX/RX Duplex. TX and RX PMA data rate is 10312.5Mhz; PMA reference clock f...
paveetirrasrie_Altera
1 year agoHello Mel_tong,
Good day to you.
Have you tried with design example instead? And the latency for A10 and Agilex 7 is different. This 2 board has different latencies.
Pavee
mel_tong
1 year agoHi Pavee,
I used the example of E-Tile Ethernet IP for Intel Agilex 7 FPGA and it worked fine.
But I couldn't find design example of E-Tile Transceiver Native PHY Intel Agilex 7 FPGA IP, so I made one according to the User Guide. The result is unstable.
Can you provide an design example of E-Tile Transceiver Native PHY Intel Agilex 7 FPGA IP?And what is the latency of phy for Agilex 7? Do you have specific data?
tong
