E-Tile Transceiver Native PHY Intel Agilex FPGA IP refclk error
- 2 years ago
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Kshitij Goel
Error(175022): The HSSI_XCVR could not be placed in any location to satisfy its connectivity requirements
Error(175006): There is no routing connectivity between source HSSI_REFCLK_CLUSTER and the HSSI_XCVR
Error(16234): No legal location could be found out of 24 considered location(s). Reasons why each location could not be used are summarized below:
Error(175001): The Fitter cannot place 1 HSSI_XCVR, which is within E-Tile Transceiver Native PHY Intel Agilex FPGA IP serdes_xcvrnphy_fme_410_yhezbna.
Error(14566): The Fitter cannot place 2 periphery component(s) due to conflicts with existing constraints (2 HSSI_XCVR(s)). Fix the errors described in the submessages, and then rerun the Fitter. The Intel FPGA Knowledge Database may also contain articles with information on how to resolve this periphery placement failure. Review the errors and then visit the Knowledge Database at https://www.intel.com/content/www/us/en/support/programmable/kdb-filter.html and search for this specific error message number.
Error(15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
Error(16297): An error has occurred while trying to initialize the plan stage.
Error: Quartus Prime Fitter was unsuccessful. 11 errors, 2 warnings
Error: Peak virtual memory: 13325 megabytes
Error: Processing ended: Thu May 9 17:18:59 2024
Error: Elapsed time: 00:05:46
Error: System process ID: 71646
Error(21794): Quartus Prime Full Compilation was unsuccessful. 13 errors, 127633 warnings
