alexforencich
4 years agoE-Tile PTP timestamping issues
I am running into some odd issues with PTP timestamping on the E-Tile on both Stratix 10 DX (Intel S10 DX dev kit) and Agilex F (DE10-Agilex).
Ultimately, what I want to be able to do is run a bun...
paveetirrasrie_Altera
4 years agoHi ,
Regarding design example, you can try to verify whether the same issue happen on design example.
You may try to load up the TX side of the link to full 10G line rate and observe the ptp4l behavior.
Kindly do let me know if it helps.
Pavee
