13 years agoDVI to Ethernet
Hello All, I'm looking at my options to build a system where a video signal from DVI would be converted to ethernet packets. This would be for a streaming application. DVI data is converted w...
13 years ago --- Quote Start --- It is possible to stream 720p and afaik it's documented in SMPTE2022 standard. Unfortunately, I don't have it... :( --- Quote End --- Well..agreed. But I seldom seen the industry using it, unless it is absolutely necessary. Pushing 900Mbps thru a 1G network is rather tough, unless it is C-class. I have only seen HD on 10G network so far.
