13 years agoDual standard SDI IP core
Hi I am trying to implement dual standard SDI reciver in Altera Cyclone IV (F485) EP4CGX30CF23 device. 1. Need 4 dual standart SDI reciver in one QUAD. 2. Each should be inte...
13 years agoIf you need 4 dual standard receivers, you may instantiate 4 dual standard SDI IP.
Each one must have an unique starting channel number. So you may use 0, 4, 8, and 16. For the dynamic channel reconfiguration, you can study an example in the folder "Your quartus ii installed folder\version\ip\altera\sdi\example".
