15 years agoDual port RAM shared between Nios and async interface
Hi all, I want to upgrade an existing system and I wonder if anyone can give me hints. I have a board with CIII device with Nios and an external Analog Device DSP: both Nios and DSP need to a...
12 years agoAfter reading this post and other related posts I decided to stay away from using Dual port RAM shared between Nios and async interface in QSYS.
If not for BadOmen's advice, then You never know what could be the problem. To start with I decided to try this reliable approach: --- Quote Start --- The current (working) implementation was: - sopc system with Nios and pio bus - external lpm ram component in dual port mode. - Nios accesses ram through pio bus --- Quote End --- To learn how to do it correctly from the start I would like to learn the way You did it although it might seem simple. Would You please publish it?
