15 years agoDual port RAM shared between Nios and async interface
Hi all, I want to upgrade an existing system and I wonder if anyone can give me hints. I have a board with CIII device with Nios and an external Analog Device DSP: both Nios and DSP need to a...
13 years agoYou are welcome. Also as a heads up I discourage people from using the synthesis translate on/off attributes in verilog/VHDL. That is what causes the comment lines from being used as the synthesis source, so I don't recommend doing that because it's confusing. When you write your HDL if you want to have seperate synthesis and simulation code I would split those out into two file sets instead, this is much cleaner in Qsys as well.
