15 years agoDual port RAM shared between Nios and async interface
Hi all, I want to upgrade an existing system and I wonder if anyone can give me hints. I have a board with CIII device with Nios and an external Analog Device DSP: both Nios and DSP need to a...
15 years agoHi HJS,
I implemented your solution and it works perfectly! Thank you again. Could you answer one last question? Just because I read Avalon specification but I'm not sure if I understood everything. Following your hints, I now have a sopc system exporting address,be,cs,rd,wr,writedata input signals and readdata,waitrequest output signals. Connecting to these signals my external processor can now rd/wr data on the onchip dpram. Suppose now the bus I connect to needs arbitration, for example because I connected to a multi master bus, or the main Avalon bus, as I asked in the question above. Point 1 is ok: host processor is sync to Avalon clock domain Regarding point 2, is the waitrequest signal enough to manage master accesses? I mean, should host processor simply drive cs, rd or wr, be, addr signals and hold until waitrequest signal is asserted or a more complex handshake logic may be required? I want I minimal implementation, then no arbiterlock, pipeline or burst functions Regards Cris
