10 years agoDSP CIC problem
I am observing a strange (to me) behaviour with a CIC IP instantiated in dsp builder (12.1sp2). I am using it to decimate a 10 MSample/sec signal to 100 KSample/sec. I used the following parameters: Filter type: Decimator Number of stages: 3 Differential delay: 1 Rate change factor: 100 Variable Rate Change Factor Options (disactivated) Number of interfaces: 1 Number of channels per interface: 1 Input data width: 16 bits For the output I’ve tried to use also full output resolution, but the "problem" is still present. If I use more than 3 or 4 bits for the amplitude of the input signal (signed), then I obtain the results I expect, but with less bits no. If I use a 10 KHz signal as input I obtain the output as I expected (a 10KHz sampled at 100 KSample/sec) even with one only bit of amplitude, but with a 1 KHz signal the output is different (it seems somehow distorted). Please have a look at the screenshots present in the attachment. I find this behaviour very strange; probably there is some DSP reasoning I am ignoring. Maybe in order to obtain the expected results even with a 1 KHz tone I should configure the CIC differently or use it with some workaround. Any advice is more than warmly welcome. A_G761 Reply
How I can ask question on this forum?
Can some one please post the link please?
