14 years agoDSP Builder installation issue
Hello, i'm working with Windows 7 64 bits. and I installed Matlab 2011b 32 bits (to have a full compatibility with DSP builder). I removed the "read only" property from all the files but the ...
14 years agoYes, this is a change that was made in 12.0.
Another new change is that the installer will let you select multiple versions of MATLAB (if you have them installed). Then when you look in the start menu, you will see an option like "Start in MATLAB R20xxx (xx-bit)" for each MATLAB version you selected.
