zlan01
6 years agodo the LPM_SHIFTREG must be used in the spi serial receiving code when the clock fequency is too fast?
input spi_data_i; output reg spi_data_o; reg [15:0]shift_sender; reg [15:0]shift_receiver; code 1: spi receiving code========================================================= always @(po...
KhaiChein_Y_Intel
6 years agoHi,
May I know which device you are using? It is mentioned that the receiving code cannot receive any data using Verilog to implement the shifting in register? Could you explain in details and provide error message (if any). Do you check the simulation result and sdc constraints?
