AWu6
6 years agodma read master and write master specification
is there any document about the detail of sgdma read master and write master? i can only get the simple doc with only signal spec, not timing diagram and spec, so I'm confused about how to use it s...
RichardT_altera
6 years agoDMA Read and Write Block:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=378
Avalon Interface Specification (Typical Read and Write Transfers):
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf#page=21
In the Platform Designer, you can click on the Data_Write_Master and the it will shows an example of a waveform.
Click the details on the top right corner to learn more.
