15 years agoOkay, now it works. I had marked the "extended feature" checkbox in the SOPC configuration of the dispatcher core. But on the software side I used the standard descriptor. It shows that you MUST use the extended descriptor as soon as you enable the extended feature checkbox. The documentation was not 100% clear about this, only: "In order to use the extended format you must select 'enhanced features' in the dispatcher...". I probably assumed that the standard descriptor is simply defaulting to certain values, when used in "extended" mode.
Second thing I noticed is that when you open the included quartus example project, the DMA is wired incorrectly. E.g. the Dispatcher-READ-Response-Sink is connected to the WRITE-master-response-port. Can you confirm this? I attached a picture... there I just opened the freshly unzipped example project. Regards, Sebastian
