13 years agoDivider fail setup constraint
i can't meet constraints of a 64 bit divider,
i added 64 stages of latency inside divider. How can i do?3 Replies
use a slower clock?
i found the problem!!
if i disconnect the aclr, my divider setup slack increase noticeably! i think if a reset is inferred, more logic is required so this slow down the divider. if a reset isn't required, don't use it!! - Altera_Forum
i'm sorry i've not solved.
if i disconnect the aclr, the whole divider is kept in reset! so the timing are right but unuseful. I tried to use a slower clock. I instantiated the PLL, the input of the PLL is Clock, the default signal. I made 2 Outputs and i would use these in DSP Builder, PLL_clk0 => 100MHz -- same frequency of Clock PLL_clk1 => 50 MHz am i right to run my design with the PLL_clk0 and the divider with the PLL_clk1 ?
