13 years agodft problem
greetings, hi i have typed followin code to verify samplng theorem but the answer is coming something different.may i know the reason. clc; fs=800; t=0:1/fs:1 x=cos(2*pi*400*t); xm=(f...
13 years ago --- Quote Start --- You're doing: t=0:1/fs:1 x=cos(2*pi*400*t); The step is 1/fs, which is 1/800 = 0.00125 This means, that from range 0 to 1, every 0.00125 step You'll get a new frequency (because argument 't' in cosine function is changing), that is: 800 results. So what do You expect in frequency domain to see? --- Quote End --- but my signal is cosine and the sampling rate is also twice of highest frequency ,so corresponding i must gate only two frequency component.
