OABBA1
6 years agoDesign contains X blocks of type combinational node,However, device contains only X
I am using a cpld that contain 40 block but my design have 288 block, there is a way to optimise the design without changing the device
thank you
- KhaiChein_Y_Intel
The required block is 7x of the available block, which is not so possible. You will probably see a Fitter error about not enough resources during compilation.
KhaiY
- KhaiChein_Y_Intel
May I know if you have any updates?
KhaiY
