chrisssynco
1 year agoDelay in SPI-to-Avalon-MM IP Response After MAX10 Reset
Hello everyone, I’m using the SPI-to-Avalon-MM IP to enable communication between an external microcontroller (MSP430) and a MAX10 FPGA (MAX10M50DAF256CG). In my setup, the microcontroller acts as t...
- 1 year ago
Let me know if you have any further update or concern?
Sheng
ShengN_altera
1 year agoHi,
Another thing is that could you confirm that the 9ms delay measure not include the internal configuration time? Because internal configuration time will possible take until 9ms if check this document https://cdrdv2-public.intel.com/666495/ug-683865-666495.pdf table 7. Internal configuration time is from nSTATUS goes high to CONF_DONE goes high.
Sheng
