Delay in SPI-to-Avalon-MM IP Response After MAX10 Reset
- 1 year ago
Let me know if you have any further update or concern?
Sheng
That duration after CONF_DONE signal rising is for device initializing (Initializes internal logic and registers && Enables I/O buffers) before enter user mode if check this document https://cdrdv2-public.intel.com/666495/ug-683865-666495.pdf page 30,32:
The initialization sequence begins after the CONF_DONE pin goes high. The initialization clock source is from the internal oscillator and the MAX 10 device receives enough clock cycles for proper initialization.
regards,
Sheng
The time it takes for the PLL to lock is quick - a consistent 248 us. But shouldn't it be the case that the device should be good to go after the lock signal going high? The device takes much longer to function after this lock signal going high - on the order of milliseconds.
