15 years agoDelay for video IPs
I've seen that there's an ip to delay (to a max of 16 clock cycles) signals from avalon-ST. Unfortunatly, it does not support backpressure, so I suppose I can't use that to delay signal from streaming-video packet.
I tryed to write a custom blok to delay my signals, but it does not seem to wok. Well, sop, eop etc seems to work properly, but i see something like a vertical square pulse in the middle of the screen. I only suppose that data_valid is not regular or has the same clock speed so it is not correcty stored in memory. I'd like to know HOW can I properly add a delay to my system Any hint would be appreciated. If someone could find it useful, the code I wrote is --- Quote Start --- module shift_reg_ram_12# (parameter LENGTH=11) ( input clk, input reset, input we, input dout_ready, input [15:0] din_data, input din_valid, input din_sop, input din_eop, //source output din_ready , output reg [15:0] dout_data, output reg dout_valid, output reg dout_sop, output reg dout_eop ); reg [19:0] mem [15:0]; reg [4:0] addr; always@(posedge clk) begin if (we) mem[addr] <= {din_data,din_valid,din_sop,din_eop}; {dout_data,dout_valid,dout_sop,dout_eop}<= mem [addr]; end always @ (posedge clk or posedge reset) begin if (reset) addr <= 0; else if (we) begin if (addr<LENGTH) addr <= addr + 1; else addr <=0; end end assign din_ready=we; endmodule --- Quote End --- Best regards PhateNo RepliesBe the first to reply
