SDasa2
6 years agoDear Sir, just before 15 days we got ARRIA10GX development kit . 1.We connected bitec FMC HDMI connector RECEIVER sink to PC GPU GTX1050. and connected 4k tv to the transmitter side.
when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV. we installed quartus prime 17.1 pro and the ...
- 6 years agoHi Sir, I installed quartus19.3 prime pro version and while generating the example design THE WARNING MESSAGE CAME ABOUT NIOS 2 SOFTWARE CAN NOT BUILT. image attached. HDMI Intel® FPGA IP User Guide Updated for Intel® Quartus® Prime Design Suite: 19.3 in this datasheet page no 4 : related information arria10 gx example design link shows the following information on first page HDMI Intel® Arria 10 FPGA IP Design Example User Guide Updated for Intel® Quartus® Prime Design Suite: 18.1.. *I generated design example in 19.3 AND COMPILED * *1. which quarus prime version i have to instal ?* *2. compilation time is 40 minutes . how can we reduce compilation time? * *after loading sof file sink detection is not there .*
SDasa2
6 years agoHi Sir,
Our FAE is in contact with INTEL he raised a case, for the same kit.
as per his suggestion as uhd design is complicated version he told to refer a design hdmi tx_rx retransmit i will attach data sheets .
so i installed quartus 19.3 prime pro version and for this we have to install NIOS2 ide MANUALLY
HENCE WHICH VERSION OF NIOS 2 I HAVE TO INSTALL?
I CREATED THE EXAMPLE DESIGN AND LOADED THE SOF FILE . BUT ONE OF THE GRN LED "D8" LED IS BLINKING CONTINUOUSLY.
IF I FOUND THE TX RX DATA PATH OK I HAVE SOME DOUBT ON MY DESIGN I WILL INFORM U ABOUT THAT.
*Quartus Prime (includes Nios II EDS)*
*Size:* 2.8 GB *MD5:* 7C1CDF9CEDCB81C730C5EC3BE15F6398
** Nios II EDS on Windows requires Ubuntu 18.04 LTS on Windows Subsystem
for Linux (WSL), which
requires a manual installation.
** Nios II EDS requires you to install an Eclipse IDE manually.
SO AS PER YOUR OPINION WHICH TOOL I HAVE TO INSTALL?
PLS CLEAR MY PROBLEM AS IT IS VERY URGENT FOR OUT TESTING PURPOSE
THANKS AND REGRDS
d.suvarna
BoonT_Intel
6 years agoHi Sir,
See the instruction from this link for the IDE installation
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
