Dear Sir, just before 15 days we got ARRIA10GX development kit . 1.We connected bitec FMC HDMI connector RECEIVER sink to PC GPU GTX1050. and connected 4k tv to the transmitter side.
- 6 years agoHi Sir, I installed quartus19.3 prime pro version and while generating the example design THE WARNING MESSAGE CAME ABOUT NIOS 2 SOFTWARE CAN NOT BUILT. image attached. HDMI Intel® FPGA IP User Guide Updated for Intel® Quartus® Prime Design Suite: 19.3 in this datasheet page no 4 : related information arria10 gx example design link shows the following information on first page HDMI Intel® Arria 10 FPGA IP Design Example User Guide Updated for Intel® Quartus® Prime Design Suite: 18.1.. *I generated design example in 19.3 AND COMPILED * *1. which quarus prime version i have to instal ?* *2. compilation time is 40 minutes . how can we reduce compilation time? * *after loading sof file sink detection is not there .*
hi, I don't see any attachment. Can you please attach again. Also, based on your current description, it seem like completely different with what you reporting in the beginning. Please confirm what is the actual issue that you are facing now.
- BoonT_Intel6 years ago
Hi Sir,
See the instruction from this link for the IDE installation
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/why-does-the-nios--ii-not-installed-after-full-installation-of-t.html
- SDasa26 years ago
Hi Sir, as per this links I installed nios2 _eclipse and crated example design again . - SDasa26 years ago
ATTACHED OTHER IMAGE RED MARK DURING COMPILATION . - BoonT_Intel6 years ago
Hi Sir,
What do you mean by red mark during compilation? is it compilation error?
I don't see any image attach here.
- SDasa26 years ago
Dear Sir,
as per the links attached by u, I installed nios2 _eclipse and crated example design again .
1.eclipse-cpp-mars-2-win32-x86_64
2.quartus-19.1-0.02-linux.run
I am attaching the images again.
still the warnings came after example design creation. and other one is after compilation warning
- SDasa26 years ago
Dear Sir, during example generation creation this warnings came. warning : hdmi_0 : window subsystem for linux (WSL) is not installed. warning : hdmi_0 : nios software will not be built. and after compilation : warning TCL script file : software/tx control /mem init/mem_init.qip not foud. i loade the sof file one of rx status green led blinking. pls give the solution immediately. - BoonT_Intel6 years ago
Here, here is the step to install WSL
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/how-do-i-install-the-windows--subsystem-for-linux---wsl--on-wind.html
- SDasa26 years ago
Dear Sir, I installed quartus prime pro version 18.1 and generated TX_RX example design whatever display is coming from GPU source is displaying in SINK MONITOR. NOW- we have to use HDMI RX AND TX IP CORE AND DDR4 MEMORY WITH SOME LOGIC TO BE IMPLEMENTED IN THE CODE . I KNOW VHDL LANGUAGE AND NOT FAMILIAR WITH VERILOG AND NIOS2 SOFTWARE. SO FOR IMPLEMENTATION OF OUR LOGIC WHICH IP CORES I HAVE TO USE . IS NIOS2 COMPULSORY . HOW SHOULD I PROCEED . - BoonT_Intel6 years ago
Regarding using which IP cores, it is depend on your application needs. I can't tell you which IP that you need without knowing your needs.
By the way, quartus also support VHDL.
- SDasa26 years ago
i am using quartus 17.1 pro version pls find the attached txt file for nios 2 build its teeling permission denie
