SDasa2
6 years agoDear Sir, just before 15 days we got ARRIA10GX development kit . 1.We connected bitec FMC HDMI connector RECEIVER sink to PC GPU GTX1050. and connected 4k tv to the transmitter side.
when we loaded the precompiled sof file to the kit --- in nvide control panel its detecting the arria10gx card. but there is no display on source -4K TV. we installed quartus prime 17.1 pro and the ...
- 6 years agoHi Sir, I installed quartus19.3 prime pro version and while generating the example design THE WARNING MESSAGE CAME ABOUT NIOS 2 SOFTWARE CAN NOT BUILT. image attached. HDMI Intel® FPGA IP User Guide Updated for Intel® Quartus® Prime Design Suite: 19.3 in this datasheet page no 4 : related information arria10 gx example design link shows the following information on first page HDMI Intel® Arria 10 FPGA IP Design Example User Guide Updated for Intel® Quartus® Prime Design Suite: 18.1.. *I generated design example in 19.3 AND COMPILED * *1. which quarus prime version i have to instal ?* *2. compilation time is 40 minutes . how can we reduce compilation time? * *after loading sof file sink detection is not there .*
BoonT_Intel
6 years agoSee if the NIOS generating issue affected by this:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2019/why-does-hdmi-intel--fpga-ip-design-example-do-not-generate-prog.html
By the way, your previous message seem broken and hard to understand. I think the reason is the image is missing. Please re-construct your message again so that I can understand your problem clearer. Thanks
